Hyundai Alarm Kumandası Programlama ?
'Teknik Sorunlar ve Çözümleri' forumunda Ersin tarafından 6 Temmuz 2010 tarihinde açılan konu
    Orjinal Hyundai Alarm Kumandasını Programlamayı Bilen Varmı ?
    Nette Şöyle Bir Yazı Buldum Ama Gavurca https://www.hyundaiclubtr.com/smileys/smiley36.gif Yazıyor Çözmesine Çözdüm Ama Memory Switch Falan Diyor O Switch Nerde Onu Bilemiyorum
    Step1
    For a 1994 to 2006 Sonata, a 2001 to 2006 Elantra, a 2000 to 2006 XG350 or a 2001 to 2006 Santa Fe, you will need to access alarm system control module. On most of those vehicles it is located on the driver's side fascia panel. But on the Sonata, the facia panel is in the center.
    Step 2
    Once you have found this module, you will want to ensure that the memory switch is in the OFF position. Then turn the ignition on.
    Step 3
    Wait 5 seconds and set the memory switch to SET position and then press the remote transmitter lock button to send the code to the alarm system control module.
    Step 4
    If you would like to program a second remote transmitter then you will need to press second remote transmitter lock button.
    Step 5
    Next set the memory switch to off, then turn the ignition off. You can confirm your programming by locking and unlocking the vehicle with both of the remotes.
  3. Ersin
    Abi BU Sonradan Takılan Alarmlarda Kontağa TAkıyoduk Kontağı Açıyorduk 10 Sn Falan Kapı Açma Butonuna BAsıyorduk Program Moduna Geçiyordu Sonra Kullanılacak Kumandalara Basıyorduk Programlanıyordu..Bnim Programlayacağım Da Orjinal Kumanda Ama AÇmıyor İştehttps://www.hyundaiclubtr.com/smileys/smiley11.gif
  4. Ersin
    Bide Bunu Buldum
    Insert your key into your car's ignition and turn it two clicks to the
    right, onto the "On" position (or one click short of turning the
    ignition on).
    Set the switch on your remote from "Off" to "Set."
    Press
    the lock button on your keyless remote and hold it until your car
    emits a small beep.
    Turn your key back to
    the "Off" position and press and hold the lock
    button on your remote one more time.
    Replace the switch on your
    remote from "Set" to "Off" again, remove your
    key from the ignition and test your remote to see if the programming
    has worked.<div style="color: rgb(0, 0, 0); text-align: left; text-decoration: none; border: medium none;">
  5. MSC
    Ersin boşuna zorlama, orjinal kumandanın nasıl programlandığı resimlerde görünüyor. Hi-scan pro'yu malak serviste gördüm ama ellerinde keyless adaptörü var mı bilmiyorum. telefon açıp sorman gerekiyor.
  6. Ersin
    Peki Abi Sen Geçen Gün Dışarda Yaptırdın Ya Onlar Nasıl Yaptı ? Onlarada Yaptırabiliriz Garantiyi Bozuyorum Zatenhttps://www.hyundaiclubtr.com/smileys/smiley1.gif
  7. MSC
  8. Ersin
    Anlamadığım Bu Orjinal Kumandası Niye Çalışmıyorhttps://www.hyundaiclubtr.com/smileys/smiley18.gif Kumandanın Işığıda Yanıp Sönüyor Ama Arabada Tık Yok
