Birazda Hyundai dışı bilgi alalım.https://www.hyundaiclubtr.com/smileys/smiley2.gif <!--[if gte mso 9]><> <w:Word> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:TrackMoves/> <w:Trackatting/> <w:HyphenationZone>21</w:HyphenationZone> <wunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfInvalid>false</w:SaveIfInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <wonotPromoteQF/> <w:LidThemeOther>TR</w:LidThemeOther> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> <w:LidThemeComplex>X-NONE</w:LidThemeComplex> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> <w:SplitPgBreakAndark/> <wontVertAlignCellWithSp/> <wontBreakConstrainedForcedTables/> <wontVertAlignInTxbx/> <w:Word11KerningPairs/> <w:CachedColBalance/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> <m:mathPr> <m:mathFont m:val="Cambria Math"/> <m:brkBin m:val="before"/> <m:brkBinSub m:val="&#45;-"/> <m:smallFrac m:val="off"/> <m:dispDef/> <m:lMargin m:val="0"/> <m:rMargin m:val="0"/> <m:defJc m:val="centerGroup"/> <m:wrapIndent m:val="1440"/> <m:intLim m:val="subSup"/> <m:naryLim m:val="undOvr"/> </m:mathPr></w:Word> </><![endif]--><!--[if gte mso 9]><> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true" DefSemi="true" DefQat="false" DefPriority="99" LatentStyleCount="267"> <w:LsdException Locked="false" Priority="0" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Normal"/> <w:LsdException Locked="false" Priority="9" Semi="false" UnhideWhenUsed="false" Qat="true" Name="ing 1"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 2"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 3"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 4"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 5"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 6"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 7"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 8"/> <w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 9"/> <w:LsdException Locked="false" Priority="39" Name="toc 1"/> <w:LsdException Locked="false" Priority="39" Name="toc 2"/> <w:LsdException Locked="false" Priority="39" Name="toc 3"/> <w:LsdException Locked="false" Priority="39" Name="toc 4"/> <w:LsdException Locked="false" Priority="39" Name="toc 5"/> <w:LsdException Locked="false" Priority="39" Name="toc 6"/> <w:LsdException Locked="false" Priority="39" Name="toc 7"/> <w:LsdException Locked="false" Priority="39" Name="toc 8"/> <w:LsdException Locked="false" Priority="39" Name="toc 9"/> <w:LsdException Locked="false" Priority="35" Qat="true" Name="caption"/> <w:LsdException Locked="false" Priority="10" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Title"/> <w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/> <w:LsdException Locked="false" Priority="11" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Subtitle"/> <w:LsdException Locked="false" Priority="22" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Strong"/> <w:LsdException Locked="false" Priority="20" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Emphasis"/> <w:LsdException Locked="false" Priority="59" Semi="false" UnhideWhenUsed="false" Name="Table Grid"/> <w:LsdException Locked="false" Unhid
ev faturalarındada dengesizlik vardı. kaçak elektirik tüketimindeki açıklarıda bizleremi ekliyorlar bilmem.
Bizde evde iki kişiyiz.İki laptop bir tv ve beyaz eşya var.Ayda 60tl elektrik geliyor ortalama.Ama aynı kullanımda bazen 35 40 civarı geliyor çözemiyoruz.Bir anormallik var elektrik faturalarında.
Dengesizlikler ne ki adamlar dengesiz. Ali kiran bas kesen. Kacak kullanim bedellerini kardes kardes faturalara aktariyorlar zam yapiyorlar sagkam saati bozuk diye alip kullanilmisi sifir diye takiyorlar Ben boyle Rezil bir ADALETSIZ ADALET gormedim arkadas. Soyleyecek bir sey bulamiyorum. Sadece YUH.....diyorum bu adamlara.
Hidayet kardes. Sorununa gelince Mahkemeye dahi verseniz alacaginizi ancak torunlariniz alur. Nacizane tavsiyem otomatik lambalari LED sensorlu sekle cevirin Bana dua edeceksin. Emin ol. Zatsn gidenleride amorti edecek. koyun oraya birde kamyon akusu anasini satim. 1 hafta 10 gunde bir otomatik sarj olsun. Bu isin herseyiyle maliyeti 500 tutmaz
Garanti kapsamında olduğu için, Taktıkları sayaç normal değer veriyor, aylık gelecek ft. 115-120 arası. Fakat eski sayacın tedaş tarafından kontrol sonucu arızalı çıkmaması sizce mantıksız değilmi? Alacaklı arıza durumu olsa hemen sayacı arızalı çıkarırlardı!! Taktıkları sayacın ortalamasını aldığımda tedaştan 1 yıllık fazladan ödemiş olduğumuz 1.850 alacak oluyor. Düzenleyen : H.SAHİN
özelleştikten sonra enerjisa milletin kanını emiyor ve emmeyede devam edecek bilginize... ayrıca mekanik sayacları akıllı (dedikleri) sayaclarla değiştiriyorlar,değişimden sonra size gece gündüz farklı yazması için dilekçe veririorlar sakın bu tuzağa düşmeyin.İşin açıkcasını öğrendik,siz bu dilekçeyi verdikte sonra faturanız ortalama %20 artacaktır.çünkü sabah 6 ile akşam 17 arası ucuz,akşam 22 ile sabah 6 arası ucuz dedikleri tarife,malesef en çok tüketimin olduğu akşam 17 ile akşam 22 arasında tam 2 kat fazla yazmaktadır.bu yüzden sakın dilekçe vermeyin. Extra olarak,alıp takın demiyorlar zorla luna ismiyle meydana çıkan dandik bir sayacı 42 tl ye bize satıyorlar,yine hangizenginin,zengenliğine zenginlik katacaklar kim bilir.
Nasıl bir ülkede yaşıyoruz arkadaş.Filmlerde izlerdik önceden şimdi resmen kendimiz yaşıyoruz.Şeref yoksunlarının kul hakkı yiyen vatan hainlerinin kullandığı kaçak elektirikler basiretsiz yöneticiler tarafından mazlumlara yükleniyor.Dünyanın hangi ülkesinde görülmüş. Hergün zam zam zam.Endonezyada litresi 0.80 bilmem ne olan benzine zamn yaptılar diye ülke ayağa kalkıyo hükümet zammmı geri alıyo. Bizde hergün zam zam zam ama kuzu olduk resmen
bizde ara tatilde faturayı ödeyip gittik.1 ay sonra geldikbaktıkki fatura gelmiş ve hiç kullanmadığımız halde 29 tl gelmişti.saçma sapan işler dönüyo...
Arkadaşlar Bizdemi bir sorun var, Anlamadım gitti yada çok titiz inceleme yaptığımdan mı kaynaklanıyor. 1 Yıl fazladan elektrik faturası ödendi, Geçen ay Tedaş sayaç değişimi yaptı, önceki sayaçta günlük ortalama tutarımız 35-40 kw sarfiyat oluyordu, şimdi 14-15 kw düştü.. 1- Sökülen sayaç ile ilgili resmi yazı gelmedi, fakat sözlü aldığımız bilgiye istinaden sayacın arızalı olmadığı bilgisini verdiler,https://www.hyundaiclubtr.com/smileys/smiley5.gif geriye dönük kendileri borçlu çıkacağı için ( ortalama 1 yılda 1.850 TL fazladan ödeme yapımışız) Resmi yazı geldiğinde yasal işlemlere başlayacağız. 2- Fatura tutarı düşmüş,https://www.hyundaiclubtr.com/smileys/smiley32.gif bir hesaplayalım dedik, birde baktık ohhh ne güzel kayıp kacak bedeli kaldırılmış ( ft içinde 8 tl olması gereken) birde ne görelim fatura üzerinde gözükmeyen hayali KDV matrahına 20,08 TL ücret giydirmişler.https://www.hyundaiclubtr.com/smileys/smiley7.gif 23,22 TL fazladan faturaya ek. Şimdi diyecekler ya kardeşim şimdiye kadar 350-400 arası fatura ödüyordun, bak ne güzel 120 TL düşmüş hiç karıştırma boşver yine kardasın gibi söylemler var. Allah aşkına nasıl bir toplumda yaşıyoruz, Ben kontrol ettim bu farkı görüyorum, kontrol etmeyenlerin durumu nasıl olacak. Kayıp kaçak bedeli kaldırılmış bunca zaman ödenenler nasıl olacak Bukadar uzun yazım olmamıştı.. <!--[if gte mso 9]><> <w:Word> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:HyphenationZone>21</w:HyphenationZone> <wunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfInvalid>false</w:SaveIfInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:Word> </><![endif]--><!--[if gte mso 9]><> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </><![endif]--><!--[if gte mso 10]> <> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normal Tablo"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <![endif]--> http://img214.imageshack.us/img214/1617/aptnisankarl0011.jpg Düzenleyen : H.SAHİN
Kayıp kaçak bedeli kaldırıldı olarak gösteriliyor ama o bedel vergilendirme olarak alınıyor maksat halk uyanmasın. Bu arada otobandaki ışıklandırmaları hastane okul park vs dış aydınlatmasını da halk ödeyecek
