Arkadaşlar forumda vardır belki ama, ben bulmuşken burayada eklemek istedim. Yazdığım yer doğru değilse kaydırırsınız sanırım. Bazı teknik kısaltmaların anlamları;... 2WD 2-wheel drive 4WAS Four wheel anti skid 4WD 4-wheel drive 4WS Four-wheel steering 4X4 4 wheel drive, see 4WD ABC Active Body Control ABS Anti-lock braking system AC Air conditioning or Alternating current AC AC Cars (formerly known as Auto Carriers) ACC Adaptive cruise control also Adaptive chassis control AFS Advanced front-lighting system AIR CON Air conditioning ALR Automatic Locking Retractor ALS Active lighting system or automatic lighting system AMG Aufrecht, Melcher, Grossaspach ASC Automatic/Active stability control ASC+T Automatic/active stability control with traction control ASD Automatic limited-slip differential ASR Anti Slip Regulation (Audi Traction Control) ATV All Terrain Vehicle AT Automatic transmission AUT Automatic transmission AUTO Automatic transmission (also Automobile and Automotive) AWD 4 wheel drive, see 4WD & 4X4 AYC Active yaw control BHP Brake horse power BLIS Blind spot information system, infra-red sensor that helps detects those in the blind spot BMW Bayerische Motoren Werke (Bavarian Motor Works) BSD Blind-spot detection CAB Cabriolet CABRIO Cabriolet CAT Catalytic converter CC Cruise control. See also ACC CCM ccm or cm³, cubic centimetres C/CODED Colour coded C/CON Cruise control. See also CC & ACC C/L Central locking CO2 Carbon dioxide COND Condition CONV Convertible CPE Coupe CPU Central processing unit CRS Child restraint system CVT Continuously variable transmission DAC Driver Alert Control DDI Direct diesel injection DHC Drop Head Coupe DOHC Double overhead camshaft DRP Dynamic rear proportioning DSC Dynamic stability control DSG Direct shift gearbox DSP Dynamic shift programme DSTC Dynamic stability with traction control DPF Diesel Particulate Filter DTI Diesel direct-injection (Opel/Vauxhall) EARS Enhanced Accident Response System EBA Electronic brake assist, helps maximise braking in an emergency EBC Electronic brake force control (see EBD and EBV) EBD Electronic braking differential or Electronic brake force distribution (see also EBC and EBV) EBM Electronic brake management system. Optimises driving stability, traction, and braking function (BMW) EBS Electronic braking system EBV Electronic brake force distribution (see also EBD and EBC) ECC Electronic climate control ECM Electronic control module ECU Electronic control unit EDL Electronic Differential Lock EEPROM Electrically erasable programmable read-only memory EFI Electronic fuel injection EGD Electronically regulated shock absorption EI Electronic ignition EMS Electronic Management System E/M Electric mirrors ENCAP European new car assessment program - motor industry measurement/grading for car safety EPROM Erasable programmable read-only memory, programmable or erasable with UV light ESC Electronic stability control ESP Electronic stability programme, another designation for vehicle-dynamics control (FDR) E/S/R Electric sunroof ESR Electronic slip reduction, another name for ASR EST Estate E/W Electric windows FDSH Full dealer service history FFS/R Factory fitted sunroof FHC Fixed Head Coupe FIAT Fabbrica Italiana Automobili Torino FSH Full service history FT/LB Foot Pounds, The amount of energy or work needed to raise an item weighing one pound, a distance of one foot, used in the measurement of torque FWH Free wheeling hubs GMC General Motors Corporation GPS Global Positioning System GSM Global system for mobile communication GT Gran Turismo or Grand Tourism HBA Hydraulic Brake Assist HC High compression HDI High-pressure direct injection HEI High performance ignition system, transistorized ignition, contact less ignition HEMI Hemispherical Combustion Chamber H/L/W/W Headlamp Wash Wipe HID High intensity discharge (Xenon headlamps) HP Hire Purchase, finance option when buying a car HPI Hire Purchase Information, used for vehicle history check H/SEATS Heated Seats IC Inflatable Curtain airbag ICC Intelligent cruise control, Nissan distance control system; see also ACC ICE In Car Entertainment IDI Indirect (diesel) injection IDIS Integrated driver information system, similar to navigation system IDS Interactive dynamic driving system IFS Independent Front Suspension. IMMOB Engine immobiliser IPS Intelligent Protection System, integrated two-stage airbag system with retractable pedals, head/shoulder airbags, and active headrests. IRS Independent Rear Suspension. IVD Interactive vehicle dynamics K-JETRONIC Continuous injection system LCD Liquid crystal display LDW Lane Departure Warning LED Light-emitting diode LHD Left-hand drive LH-JETRONIC Same as L-Jetronic with hot-wire air-mass sensor LPG Liquified petroleum gas L-JETRONIC Electronically controlled injection system (with direct air-mass measurement) LSD Limited-slip differential LTHR Leather LWB Long wheel base MAF Mass airflow sensor Man Manual MFI Multipoint fuel injection (electronic) MFI-C Continuous multipoint fuel injection (electronic) MFI-I Intermittent multipoint fuel injection (electronic) MFI-S Sequential multipoint fuel injection (electronic) MG Morris Garages MOD Manual Over-Drive MOT Ministry of Transport Test MPFI Multi-point fuel injection (electronic) or Multi-port fuel Injection MPG Miles per Gallon MPH Miles per hour MPI Multi-point injection, fully electronic engine control MPV Multi-purpose vehicles MR2 Mid-engine Runabout MY Model Year NAV Navigation or Navigation system see also SatNav NCAP New Car Assessment Program, see ENCAP NM Newton-meter, used in the measurement of torque OBC On-board computer OCD Occupant Detection System OBD On-board diagnostics or off-board diagnostics, vehicle-internal diagnosis with internal or external test unit O/D Overdrive OEM Original equipment manufacturer OHC Overhead camshaft. Camshaft situated above the cylinder head OHV Overhead valves (the camshaft is therefore underneath) ONO Or Near Offer ORV Off Road Vehicle OVNO Or Very Near Offer PAB Power Assisted Braking PAS Power Assisted Steering PASE Passive Start and Entry. Keyless access to car and engine start (Siemens system) PATS Passive Anti-Theft System PB Power Brakes PCD Pitch Circle Diameter PCH Personal Contract Hire/Lease PCP Personal Contract Purchase PDC Park Distance Control. Parking aid PDM Power Door Mirrors PFI Port Fuel Injection P/HOOD Power hood for convertible PROM Programmable Read-Only Memory PSI Pounds per square inch P/X or P/EX Part exchange RAM Random access memory, read/write memory of a processor R/CASS Radio cassette R/C/L Remote central locking RDS Radio Data System RFT Run-flat tyre RHD Right-hand drive R/H/R Rear head restraints ROM Read-only memory. Program memory of processor, or other memory, that can only be read. ROPS Rollover protection system. Automatically extendable roll bar (Volvo) RPM Revolutions per minute RS Restraint system or Rotational speed sensor R/S/B Rear seat belts RSC Run-flat system component. Tyres with emergency-running properties. See also RFT RSC Roll stability control RV Recreational Vehicle RWD Rear wheel drive R/W/W Rear wash wipe SAAB Svenska Aeroplan Aktiebolaget, which means Swedish Aircraft Company SAS Side-impact protection, See also SIPS SatNav Satellite Navigation SBE Seat-occupied detection SCAN TOOL Tester for reading OBD error codes and other OBD data SCS Stability control system. Simplified form of ESP (Mitsubishi). Prevents vehicle tilting or skidding. SEFI Sequential electronic fuel injection SFI Sequential fuel injection SIPS Side-impact protection system (Volvo) SMPFI Sequential multi-port fuel injection SOHC Single overhead camshaft SPFI Sequential Port Fuel Injection S/R Sunroof SRC Synchro rev control SRI Sports Rated Injected or Short-Ram Intake? SRS Safety restraint system (generally includes airbag and seatbelt tensioner, normally controlled by a common control unit) STC Stability and traction control SUV Sport utility vehicles SWB Short wheel base T&T Tax and tested (TNT) TC/TCS Traction control/Traction Control System, auxiliary function with ABS TDC Top dead centre TDI Turbo diesel injection T/GLASS Tinted glass TIPTRONIC Porsche or VW electronic transmission control. The control can be operated via a small device on the steering wheel. TNT Taxed and Tested TPMS Tyre-pressure monitoring system TRACS Traction control system (Volvo) TRD Toyota Racing Development TT Touring Turismo TVR Trevor T/WIN Tinted windows VANOS Variable camshaft timing VCAR Vehicle condition alert register VDC Vehicle dynamics control VIN Vehicle identification number VSA Vehicle stability assist. System similar to ESP. VSC Vehicle stability control VTEC Variable Valve Timing, as below VVTI Variable Valve Timing, as above VW Volkswagen WHIPS Whiplash protection system WTY Warranty XDS Electronic cross-axle traction control system
Güzel paylaşım.Ah birde anlayabileceğimiz bir dile çevrilseydi Edit: Google Chrome siteyi türkçeye çevirince terimler Türkçe'ye dönüyor.
