97 otomatik elentra motor özellikleri nedir ?
'Elantra Forum - Club' forumunda why35 tarafından 24 Kasım 2008 tarihinde açılan konu
  1. why35
    why35 Kayıtlı Üye
    24 Kasım 2008
    Merhaba Arkadaşlar ,
    97 Model elentra almak istiyorum.
    97 model otomatik elentra'nın motor özellikleri hakkında bilgisi olan varmı ?
    kaç beygir max tork vs vs.
    10.750. otomatik tüplü 100 küsür binde
    sizce nasıl ?
  2. why35
    why35 Kayıtlı Üye
    24 Kasım 2008
    İnternette ararken yabancı bir siteden buldum
    belki merak eden aradaşların işine yarar diye buraya yapıştırıyorum.
    <TABLE id=compareTable cellSpacing=0 cellPadding=0>
    <TR id=ctl00_ctl10_ctl00_rper_ctl00_trTitle vAlign=top>
    <TD ="b pad5_t" id=ctl00_ctl10_ctl00_rper_ctl00_tder>1997 Hyundai Elantra Base Wagon Performance &amp; Efficiency Standard Features
    <TD ="s8_h2 mdl ctr" id=ctl00_ctl10_ctl00_rper_ctl00_tdHideColRight>
    <TR =bg_specs_contents>
    <TD colSpan=3>
    <DIV id=perance_efficiencyRow>
    <DIV style="DISPLAY: inline">-
    <DIV style="DISPLAY: inline">1,795 cc 1.8 liters 4 in-line front transverse engine with 82 mm bore, 85 mm stroke, 10 compression ratio, cast iron block, light alloy head, double overhead cam, automatic valve adjustment and four valves per cylinder
    <DIV =spacer>
    <DIV style="DISPLAY: inline">Unleaded fuel
    <DIV =spacer>
    <DIV style="DISPLAY: inline">Fuel economy EPA highway (l/100km): 7.4
    <DIV =spacer>
    <DIV style="DISPLAY: inline">Multi-point injection fuel system
    <DIV =spacer>
    <DIV style="DISPLAY: inline">Main 55 liter fuel tank
    <DIV =spacer>
    <DIV style="DISPLAY: inline">Power: 97 kW , 130 HP @ 6,000 rpm; 122 ft lb @ 5,000 rpm
    <TR id=ctl00_ctl10_ctl00_rper_ctl01_trTitle vAlign=top>
    <TD ="" id=ctl00_ctl10_ctl00_rper_ctl01_tdHideColLeft>
    <TD ="b pad5_t" id=ctl00_ctl10_ctl00_rper_ctl01_tder>1997 Hyundai Elantra Base Wagon Handling, Ride &amp; Braking Standard Features
    <TD ="s8_h2 mdl ctr" id=ctl00_ctl10_ctl00_rper_ctl01_tdHideColRight>
    <TD colSpan=3>
    <DIV id=handling_riding_brakingRow>
    <DIV style="DISPLAY: inline">3.65:1 axle ratio
    <DIV =spacer>
    <DIV style="DISPLAY: inline">Two disc brakes including two ventilated discs
    <DIV =spacer>
    <DIV style="DISPLAY: inline">Responsive suspension
    <DIV =spacer>
    <DIV style="DISPLAY: inline">Spacesaver steel rim internal spare wheel
    <DIV =spacer>
    <DIV style="DISPLAY: inline">Strut front suspension with stabilizer bar independent with coil springs , multi-link rear suspension with stabilizer bar independent with coil springs
    <TR id=ctl00_ctl10_ctl00_rper_ctl02_trTitle vAlign=top>
    <TD ="" id=ctl00_ctl10_ctl00_rper_ctl02_tdHideColLeft>
    <TD ="b pad5_t" id=ctl00_ctl10_ctl00_rper_ctl02_tder>1997 Hyundai Elantra Base Wagon Exterior &amp; Aerodynamics Standard Features
    <TD ="s8_h2 mdl ctr" id=ctl00_ctl10_ctl00_rper_ctl02_tdHideColRight>
    <TD colSpan=3>
    <DIV id=exterior_aerodynamicsRow>
    <DIV style="DISPLAY: inline">Front and rear body color impact absorbing bumpers
    <DIV =spacer>
    <DIV style="DISPLAY: inline">Coefficient of drag: 0.33
    <DIV =spacer>
    <DIV style="DISPLAY: inline">Driver and passenger internally adjustable black door mirror
